R
ruben
Guest
Although 645 Iskras have been around, the novelty (as far as I know) is the use of 220 film, for which the Iskra had to be custom adapted.
My adaptation started from a full working Iskra 6x6 bought from Vickentij Trofimov (Soviet Camera Store - Ucraine). The adaption consists of the following stages: (Kindly excuse my poor technical knowledge, and my English language limitations)
a) Dis-abling the film frame counter mechanism, in an educated manner. This includes extirpating the thin axis making holes to the film. And sealing the empty space left by the extirpation at the camera top and bottom. I have not found an educated way to do it, but fortunately, after 3 by-force-only surgeries at 3 different bodies, all 3 axis remain not broken and re-installable.
b) Designing an alternative graphic manual frame counter, and a manual graphic film advance counter. For an effective solution, i.e. a way that works acceptably fast enough, I have been experimenting schemes with my graphic program (CorelDraw). I hope some day I will post a self explanatory pic.
c) Sealing from light the camera chasis, further more. You will have to paint black ALL the chromish color parts of the back, the only exception being the film horizontal tracks above and below the square film exosure window.
d) Adding an extra pressure to the film pressure plate. This is easily achieved with the addition of 2 small rings, to be inserted between the film plate and the back's spring, around the the 2 screws attaching the film pressure plate to the back's spring.
e) Installing 2 frame patches (inserts) to transform the 6x6 square into 6x45 format. In my case, instead of the traditional way of inserting these metal parts between the bellows and the chasis, I glued the metal inserts to the square mouth, very close to the film path. The traditional way produce good and strongly attached inserts. My way produces weakly attached inserts, prong to extreme care when fidling with the rear lens compound. I was led to this way, since one of the screws attaching the bellows to the chasis, was impossible to unscrew.
Some surrounding remarks.
A) Light leaks.
Since I begun purchasing Iskras, (3 up to day) I have had light leaks. First I suspected the lens iris, then the bellows. But today I think I am smarter.
In my opinion the main suspects are both the 2 lower wheels at the bottom of the camera, and several points at the top body compound. Light entering to the top compound is prompt to reflect into the inside of the upper latch of the back and enter the film housing. Good treatment is to seal the back latches with foam, to paint black the inside of the chromish top housing of the camera, and to black-tape any hole inside the film housing, SPECIALLY the surrounds of the 2 lower wheels engaging the film, at left and right side.
B) In general, the Iskra is a very simple-mechanism camera, friendly to deal with, and amicable to surgery.
C) HOW TO REALLY SOFTEN THE FOCUSING MECHANISM.
The only known solution to this known desease has traditionally been clenaning the reels moving the lens forwards and backwards. But after doing it and lubricating, it has not produced to me a sensible result. Nevertheless I discovered a different way to soften the focusing knob. It consists in carefully unscrewing A BIT the 4 screws attaching the front side of the bellows plate. This screws are those seen surrounding the lens when you open the back, when the lens is collapsed.
Additinally you can also unscrew A BIT the upper screw among the 3 screws attaching the aluminium lens compound surrounding the lens. I am talking about the aluminium device with the stamped depth of field scale. In order to reach these 3 screws, of course, you will have to start dis-assembling the lens coumpound from its rear side: First, unscrew the inner ring surrounding the lens (this ring is not quite visible at first glance, but this is the one holding the lens to the lens compound), then the lens is released and the 3 screws visible. The one to be unscrewed A BIT is the upper one.
All these sensible and carefull un-screw actions have not produced me any light leak.
D) Back holed Iskras.
Two of my Iskras are back-holed. One is a 645 "export" model, the other a normal 6x6. Alongside with the perfect one purchased from Vickentij, which I transformed to 645, I have been working to improve the export holed model.
Surprisingly for me, the holed back, after further sealing measures, is indeed light-proof when using 120 film, and I find the holy way of advancing film quite straightforward.
The "additional measures" I took, consist in surrounding the space between the back red hole, and the film pressure plate hole, with plain cotton. And painting the cotton black.
In order to see the red hole when the camera is in case, I have holed the case too. And with the help of Prym buttons I made a kind of door, sealing the case hole at will.
Ruben
A) Light leaks.
Ruben
