Gravatar
Hey all. Does anyone know if there was a lens hood made especially for the GW690? I baught one of those cheap screw in jobs at a local shop and apparently it was not wide enough. It vinetted my corners. I like to use a hood whenever I can. Any suggestions would be appreciated.
Grav
One of my first shots with this groovy 2 ton Texas Lieca:
http://www.trekearth.com/gallery/North_America/United_States/photo404118.htm
this one should work
Grav
jan normandale
Film is the other way
Gravatar, your link brings up a "forbidden" notice.
R
rich815
Guest
Gorgeous shot Grav. Sorry, I know of no hood in particular for that lens. I have the III version with the built-in hood that some people deride but I like.
Would love to see your Fuji image on my site. See below:
Abbazz
6x9 and be there!
You could try one of these:
Rubber hood for wide angle
Metal hood for wide angle
But I suggest you try before buying, just to make shure it doesn't block the rangefinder window.
Abbazz
Abbazz
ghost
the lens is deeply recessed. the original hood is pretty shallow, so i'm guessing it's not all that important.
Gravatar
The tried hood
The tried hood
The hood I tried was a rubber job for wide angle. However, the nonconed portion of the barrel seemed a bit long for that. It did cove a portion of the rangefinder up, though it wasn't enough to cause trouble for composition. Oddly enough, I have the smaller version of this same hood on my GS645S with no problems with vinetting. I guess I will need to experiment. Rich, which of those websites were you referring too?
Grav
The tried hood
Grav
R
rich815
Guest
Gravatar said:Rich, which of those websites were you referring too?
Grav
The Fuji one.
Gravatar
It's up
It's up
I posted a copy there, Rich.
Grav
It's up
Grav
