Hoods Question To The Contax-G Community
R
ruben
Guest
Hi Friends,
On behalf of the Zeiss cause, in its broader sense, would you mind to detail the thread size of the different G system lens hoods ?
I don't think I need calliper accuracy, and ~ + - 1mm will be fair enough for me.
]Thanks,
Ruben
Ruben I don't have a clue about the thread size, but there is somebody on ebay who sells very cheap copies of the G hoods out of Shanghai. they are not a gorgeous as the real thing but they do the job.
steamer said:
Ruben I don't have a clue about the thread size.....
That's the problem steamer, it seems that beyond the owners no one else has any clue.
Cheers,,
Ruben
I am a proud owner of these hoods I just moved my calipers to a more logical place but I can't remember where that more logical place is now, so I have measured the hood with a ruler and it is about 46mm which jibes with the instruction pamphlet that calls for 46 mm filters.
And the Hologon does not accept filters.
Actually a stack of 2 old 55mm filters with their glass removed acts as a hood for the 21 mm for me. There is none available from Contax.
I think this information is pretty easy to find on the net. Anyhow, its 46mm for the 28-45-90 combo.
I have one of the Chinese GG-2 knock-offs coming in the mail any day now.
Rueben,
28, 35, 45, and 90 take 46mm filters.
21 takes 55mm filters.
16mm has it's own proprietary clip on neutral density center filter.
Cheers.
Ruben- the 28, 35, 45 & 90 all have 46mm diameter, standard pitch threads (standard as in the same as a B&W or Hoya filter) The 21 uses a 55mm standard thread for filters, but there is no dedicated hood. The 16 can only accept the gradation filter- though I don't know how that fits on, and I do not have the zooms info.
RE: Hoods Question To The Contax-G Community
Ruben,
The 21 uses a 55mm hood/filter thread. The 28, 35, 45 and 90 have a 46mm hood/filter thread. I believe that the zoom is also 46mm.
Jim Couch
Ruben
The zeiss hoods will take generic clip on 55mm filters to act as hood caps I use the 28mm hood on my Kievs, for the J12 and J3, with a 40.5 to 46 mm step ring.
Noel
