robklurfield
eclipse
Rxmd... apologies. Done.
Yes, you'd get the good scan back, edit as required, then print.
Scanning at 7200dpi will not get you any more detail, but basically you get enlarged grains, not enlarged pixels, looks a lot smoother. There may not be more detail, but it looks like there is!
Mr. Fizzlesticks said:Less experienced people will tell you that it can't be done because they don't know how to do it. I have been around a while (like some of the posters above) and have seen large prints made from 35mm that were beautiful. I have also seen them look like crap. It really just depends on you. Frankly if you want to make large prints you should get someone else to do it for you. There is a large learning curve and it seems you are at the start of it. That is not a bad thing. Like Eastwood said, a man has got to know his limitations. If you are just doing it for yourself then go for it.
