how to choose the times for split filter printing
LeicaFoReVer
Addicted to Rangefinders
5:16 AM
Hi guys,
I have been trying split printing following the instructions by Konrad Eek. So I print two test strips, one with 00 and another with 5th grade at 5 sec intervals.
I am not able to choose the best time for each as it seems highly subjective and my times are a bit guess and often not the best. I try to find the time where real white appears under 00 and real black appears under grade 5 but I often get overexposure as it is difficult to imagine the combination of 00 and 5 grades. So I end of lowering them down equally. Sometimes adjusting up or down individually. However I feel like I dont get the idea of this so I ask here to see if there is an ideal way. I might post my test strips here to discuss more clearly. Maybe my time increments should be at 2 sec.
Hi guys,
Split grade printing is at least to some extent a con. It might work for some, but it is no magic bullet and produces results demonstrably (by sensitometry) no different to finding the right contrast filter and making a print.
As Roger Hicks sagely put it, don’t believe gurus:
http://www.rogerandfrances.com/subscription/ps ignore gurus.html
Make the best print you can, dodge any shadows that need it during the main exposure, then turn the contrast down and burn any highlights that need it. Split printing, to me, makes printing harder because it increases the variables.
Marty
Hi Marty,
I found incredibly useful and easy to get a well balanced print (if your shot is well balanced). I got great prints as a beginner at my first attempt in split filtering. My previous attempt on fixed contrast paper was a hit or miss, and discouraging :)
I am only on the gray side on choosing the good combination of each exposure with each filter. I still make less attempts to get what I want compared to single filter or fixed contrast printing (mostly of course for difficult shots with difficult situations such as a lot of back lighthing etc). I think I will get there but I was wondering if there was a point I miss.
Sorry I have no split grade advice other than to keep at it and keep your experiments systematic, make sure you developer your test strips to completion, otherwise that could lead to what you're experiencing. What many don't seem to be aware of is that you don't need to fix the rougher test strips you don't intend to dry and keep, acid stop bath is enough, saves time. I too used to find the arguments in favour of split grade printing convincing, but in practice I never print negatives that would need the complex dodging and burning to really benefit. And I'm scared of introducing unsharpness by disturbing the enlarger head.
What I have found very useful in dealing with difficult highlights is flashing the paper. Often only that gives me the gentle highlight roll-off that people say film has over digital - it doesn't automatically... But contrary to what some internet guides say, the flashing needed varies, one needs to do test strips for that. I recommend trying it out anyway if you haven't yet. I have sometimes resorted to a very simple way to flash: let the enlarger head leak some light on purpose. I still have never worked with a bleach/reducer, that's next on my list. I think that, too, is in practice often easier than split grade.
In my limited experience of split grade printing, it is the exposure with the 00 filter that affects the greys - the longer, the muddier.
Split grade printing is the greatest gift of God in the darkroom, but it asks for a lot of discipline in the workflow. People who say that split grade printing produces the same print as single grade printing do not know what they are talking about.
First of all you'll need a very stable enlarger with a smooth filter drawer. I use a Focomat IIc with a very heavy wooden Leitz easel of 50x40cm.
You can use only paper with variable contrast, such as Ilford Multigrade or Adox MCC 110.
You'll only need two filters: 00 and 5. Of course, between and during the two exposures neither the negative nor the paper may move.
The 00 filter takes care of the high lights and the light grays. The 5 filter controls the deep blacks.
Usually, the exposure with the 00-filter takes much more time than the exposure with the 5-filter.
A good, digital clock with a double memory (there are two exposures every time) is really a must. I use a Hauck MSA II, perfect for the job.
Use a timer too for developing. I develop every print for 3 minutes in diluted Eukobrom.
Make enough test strips. Make the print only when you are for 100% sure of your exposure times.
Do not make more than one print at a time.
So:
Remember that there are always TWO exposures, one through the 00-filter and the other through the 5-filter.
1. carefully clean your negative and put it in the enlarger and project it on the easel
2. determine roughly both exposure times and make a test print (use f/8)
3. develop for 3 minutes; when fixed, observe the test
4. when the blacks are too light, increase the exposure with the 5-filter or decrease when the blacks are too dark
5. do the same with the whites and the light-grays with the 00-filter
6. make a print only when you are for 100% sure of your exposure times
Good luck!
Erik.
split grade print:
[...] People who say that split grade printing produces the same print as single grade printing do not know what they are talking about. [...]
For straight prints? Bold claim, can you explain why? VC paper is made up of two or more layers that have different contrast and are sensitive to blue and green to different degrees. Contrast is varied by using these layers in different ratios, through the ratio of green and blue light. I don't see how it possibly could make a difference whether you give the paper the same proportions of green and blue light one after the other or at the same time.
4. when the blacks are too light, increase the exposure with the 5-filter or decrease when the blacks are too dark.
Have you found that increasing the 5-filter time, greys from the 00-filter become darker? I am wondering if this is normal or there is something wrong with my filters. Not by much but I can notice it on the final print.
I have seen this, but I've thought that this was caused by the 00-filter.
However, when you expose long enough with any filter, the whole paper will be black, because the paper is sensible for all the light that comes through them.
The effect of the filters is based on the sensibility-curves in the paper. That is how I understand it.
In splitgrade printing it has no use testing the effect of one filter, you'll always use two filters.
I've noticed that in time, ten years or so, the color of the filters changes. Then it is time to buy a new set. Colors often fade in light. That is why color printing is totally useless.
Erik.
Erik.
This is the reason of question actually. Trying to guess time of each filter separately sounds fine (frome separate test strips) but when combined sometimes the whole image gets dark (overexposed) as both affects partly each other. So I decrease time equally. I wonder if there is a way to prevent this.
Erik.
This is the reason of my question actually. Trying to guess time of each filter separately sounds fine (frome separate test strips) but when combined sometimes the whole image gets dark (overexposed) as both affects partly each other. So I decrease time equally. I wonder if there is a way to prevent this.
That is very simple to see. As you say, in the paper are two layers, a hard one and a soft one. The hard one responds maximally to filter 5 and the soft one maximally to filter 00. That is why only these filters are used. There are two different exposures: one with filter 5 and the other with filter 00. So both layers can be manipulated independent to one another. If the length of the exposure with filter 5 changes, this will have an effect on the hard layer and if the exposure with filter 00 changes, this will have an effect on the soft layer.
Erik.
Unless you already do this: Do the hard test strip first, select an exposure time that, based on experience, is maybe a little shorter than what looks good (start thinking of this fudge factor as percentage rather than absolute time so you can transfer to different print sizes and neg densities). Then expose that on the test strip for the soft exposure, then make your soft test exposures on it. This way you have the cumulative exposure at least in the second test strip.
You have to make two different exposures: one with filter 00 and the other with filter 5. You must not combine them. Usually the exposure with filter 00 is long and the exposure with filter 5 is short.
Simply said: filter 5 works on the dark areas and filter 00 works on the light areas. Two exposures.
The other filters of the set you can throw away.
Erik
Unless you already do this: Do the hard test strip first, select an exposure time that, based on experience, is maybe a little shorter than what looks good (start thinking of this fudge factor as percentage rather than absolute time yo you can transfer to different print sizes and neg densities). Then expose that on the test strip for the soft exposure, then make your soft test exposures on it. This way you have the cumulative exposure at least in the second test strip.
NO, completely wrong. There is no cumulative exposure. There are only two different exposures, one with filter 00 and the other with filter 5. That is all. "SPLIT-grade"
But there is often a lot of testing before the optimal effect is found, that is true, but only to find the correct times of both exposures.
Erik.
Erik.
Sure, my point is however any filter between 00 and 5 passes a mixtures of the only (in terms of what the paper responds to, subtractive filters will also pass other, irrelevant wavelenghts) green or blue that 00 and 5 pass, respectively. Whether you get a certain mixture of green and blue onto the paper at the same time, as with the in-between filters, or one after another, as with the 00 and 5, shouldn't matter in theory unless I (and some others who have written about this) missed something. I haven't done a side by side test, but I might at some point although I haven't heard any argument to make me question the theory. I think it's likely that casual testing would be biased toward the method the tester is used to as they'd find it easier to dial the print in in that, that's why I take anecdotal evidence with a grain of salt.
Nothing of that is to dispute that split grade works.
