Here is the stuff you will need:
And here is what to do in 11 easy steps:
1) Put the reels, tank, film cassette(s), church key style bottle opener and some small scissors (if they have rounded tips, it's better) into the changing bag. Reach in through the sleeves. Use the pointy end of the bottle opener to pry the cap without the protruding spool end, off of the film cassette. Use the scissors to cut the leader off the strip of film.
2) Load the film onto the reel. (The process is different for loading stainless reels and for loading plastic reels.) Once you get the entire film strip onto the reel, cut off the spool.
3) Put the reel into the tank and close it. Take the tank, tools and detritus out of the changing bag.
4) Check the
Massive Development Chart for time and temperature recommendations for your combination of film and developer. If it is inconvenient to use 68°F, you can convert the temperature using the
time/temperature conversion chart.
5) Take the tank and chemicals to a bathroom sink. Develop for the recommended time. Agitate for the first minute then every 30 sec there after for 5 seconds (turn the tank over three times. Tap it on the sink or tray when done agitating to dislodge any bubbles.)
6) At the end of the developing time, pour the developer down the drain. Be sure to include the time for the tank to drain in the total time. Then fill the tank with water agitate for 15 sec. Pour it out and refill it with water, agitate, then pour it out.
7) Fill the tank with the working rapid fixer solution. Agitate for the first two minutes then every 30 sec thereafter for 4 to 5 minutes of time in the fixer, pour the fixer back into the fixer bottle. You can reuse fixer about six times. After the last use, pour it into a waste container (for later disposal.)
8) Fill and empty the tank several times with water and remove the top of the tank. Run water constantly into the tank so that it changes the water in the tank in about 30 seconds. Keep it in the wash water stream for 20 minutes. Pour the wash water out.
9) Fill the tank with wetting agent solution and gently swirl the negatives for a minute. Pour the wetting agent down the drain and take the reels holding the negatives out of the tank.
10) Gently rap the reels against your hand to dislodge any clinging liquid, then de-spool and hang the film to dry in an enclosed shower or other dust free environment. The time it takes for the film to dry depends on the humidity - from an hour to overnight. The slower the film dries, the less curl it will have.
11) Wash the tank and reels, and dry with a lint free towel. Now cut up the film and put it into sleeves. Label the sleeves so you can remember what is on the negatives.
That's all!
