How to get thin black line when printing.
6:21 PM
I know you need to file down a carrier. But whenever I do that it always becomes a sloppy border. The lines are never even. I just want a nice thin line around my prints.. help??
Leitz provided a dedicated full-frame (25x37 mm) negative carrier for use with their V35 enlarger. It was slightly bigger than the one supplied with the V35 enlarger as standard and allowed for printing of a thin black border around the image. Perhaps other enlarger manufacturers supplied something like this too?
Easiest method I have seen is to create a card or board which is slightly smaller than the print area (and has rectangular corners of course). You put it into the easel lower / left corner and expose, then upper / right corner and expose.
If I recall correctly, the method is described in Tim Rudman's printing book.
Lars
The Durst M670 enlarger was delivered with a set of two black chrome negative frames for the holder. One of them is the size of a slide frame, the other has a 25 X 37 opening. With glass on the other side I get a neat black border, you get to see light eating into the frame.
The part is called Durst SIVOMA
Cheers
25x37mm carrier (Dunco has it also, even still in production) but the lines are never straight then. Or a Versamask easel with fixed frames where you can do very easily the inner part with a perfect straight line. Alternative the 4-blade easel with carefull adaptation.
It takes both the filed out negative carrier and a high quality 4-blade easel.
The exposed image area will vary slightly from camera to camera and, if you are an RF user with a penchant for wide angle lenses, it will vary lens to lens on the same body. The only way to get a uniform neat thin line is to have a good bit of film outside of the image visible through the carrier and then mask it carefully at the easel.
back when i used an enlarger I would file out the negative carrier to get what you want (ad it looks like you've already done). I was always sloppy and like the black edges looking a litte rough rather than perfectly straight like a border. If you want a straight black border use black tape on the print.
