Canon LTM HU Canon 50/1.5
"a very slight (non-axial) play in the front, which appears to be quite common with this particular lens"
what the hell he is talking about? Absolutely no play in my 1.5/50!
"there is some haze on the inside of the rear element which will affect image quality and should be cleaned if you intend to use the lens for picture-taking"
No thanks for 249 USD. I once had a 1.8/50 Canon with "hazed" rear element. At my repairman's workbench it turned out that the damage was already permanent.
cheers Frank
