Canon LTM i had a thought...
back alley
IMAGES
8:37 AM
...do i really need a 100/2 lens when i'm quite happy with the 85/2?
i was thinking about the 100 framelines in the p, but i'm guessing that i could easily live with them for the 85.
with the money for a 100/2 i could really invest in my canon 35 collection.
i use 35 more than 85/100.
i enjoy the 35 more etc.
throw your ideas at me please!
i need to know if i'm missing something or not considering something here.
joe
Well Joe,
If you were a collector, you would HAVE TO HAVE the 100mm F2. The 85mm F2 should fulfill all of your short Telephoto requirements, and the 135mm will make up for longer lengths. There is not enough difference from 85mm to 100mm to justify spending $300~$400. But then, how does a user justify investing in a 35mm collection? If you want to spend the money as a user, get a Canon 28mm. As a Collector, get the 100mm F2 or 35mm F1.5.
If you mostly shoot b&w (or scan your films) and don't mind cropping them to get the final composition you want, then there's no reason you shouldn't stick with the 85 and use the 100 frameline with it.
The fields of view aren't all THAT different, as a quick glance through a Canon 7 finder will show.
In other words, shooting an 85mm lens with a 100mm finder will leave all your images pretty "loose." As long as that doesn't bother you, go with it!
Joe,
What is the difference between 85mm and 100mm in the real world? Maybe 1/2 step forward with the 85mm to equal a 100mm?
I tend to use my 85mm much more than my 100mm, but that is just me. (they are also NNNNNNiiiiiiKKKKooooNNNs, not Canons).
Wayne
the difference between the viewing angle of a 85 and a 100 is very very small, if you really need that extra 15mm you can just crop the edge of the neg/print, you will lose no quality in practice. If there's no other difference between the two lenses (i don't know any of them personally), I would go for only one of them.
As to framelines, i agree with you, framing with a rf is not that accurate anyway.
Wayne: is that the Nikon E 100mm F2.8?
I have the Nikkor in 8.5cm f2 and 10.5cm F2.5. But Canon did not make a 105mm. If they had, that would have been different. like 5 different...
BUT Joe, You have the 100mm F4. The real difference in it is the weight. Want to travel light, grab the 100mm F4. Need Speed, grab the 85mm f2.
brian,
i think i have the soul of a collector but not the budget of one.
i just might be able to satisfy the collector need by focussing on one focal length and not looking at ALL of the canon catalouge.
so maybe it's 35's for me.
joe
Yes,
stick with the 85/2, I'm going to do that using the J9 on the P with the 100 lines, the threads on the 7 lens mount are a bit damaged and that lens doesn't screw smoothly, while the Voigtlander 35 does it like butter.
IMO, it's always interesting to have some extra frame in the final image, many times I've found pleasant to include those 'surprises' in the final picture.
On the other hand, Joe... if you get yourself that 100/2, you might figure out which one you like more and get rid of the other one without any loss, i guess that's an option too! Unless you know you won't be able to sell it (and i don't mean lack of buyers hehe)
joe
Joe
The Nikon 105mm f/2.5 is legendary, and deservedly so! You can't live without it. I would never part with mine. :D
Russ
Canon on Canon. Leitz on Canon. Nikkor on Canon. Steinheil on Canon. Schacht on Canon. Jupiter on Canon.
I have a Happy Canon.
But I put the 10.5cm f2.5 Nikkor on the M3. I repaired the threads, and it was just easier to use on the M adapter. But I did try it out on the Canon.
so, i bid on the 100/2 that just ended (the auction that is) and lost by 5 bucks in the last 10 seconds or so.
i needed to.
i had more cash to bid but found myself thinking that i really didn't need/want this lens.
at least not right now.
i'm happy and will stay with the 85/2.
i think i have found my kit. the combo that will work for me.
i ordered another m-grip just now for the other p.
i start shooting, in earnest, soon.
many thanks for your thoughts on this. it helped.
joe
Joe, Was that the one with all the cleaning marks on the front element?
It went for more than my Mint Nikkor 85mm F2 in LTM cost me!
Those Canon Collectors! They are getting as bad as Nikon Collectors!
The really fun thing is that I identified THREE members of this forum bidding on that lens, plus me watching it with a 'sleeping' bit that I cancelled when Joe entered, plus probably some more here watching it.
Remember Nash game theory, we need to set up a common watching/bidding system and join our forces :)
brian,
yeah, it was the one with the cleaning marks.
i thought it would go for a lesser price because of the seller's write up.
guess i was wrong.
but it all works out in the end.
oscar, i noticed a few familar names also.
we ARE a small group in the wilderness.
joe
