cnphoto
Talking of easels, larger ones are both expensive and difficult to find these days. As a cheapish temporary alternative you can print on a big bit of hardboard (or similar) using a black matte board as the masking frame. You can find a lot of standard pre-cut sizes cheaply in art shops.
that's a brilliant bit of DIY! i generally rent darkroom space, but now have most of the equipment to print at home if i wanted, if i do print large this is what i would probably end up doing 🙂
