comp_wiz101
Compulsive Tinkerer
Dear me, it's been a while since I've posted. I'm baaaack!
One of the toys I've picked up since the last time I've been around is a cheap 3D printer.
I don't really like having selenium meters running all the time when a camera is on the shelf, so I designed a cover that lightly fits over the meter housing - even added a little loop if you want to have the cap retained by a string. Sure beats using some sticky gaffer tape.
Anyways, if you have a 3D printer, feel free to download and print your own... and if you don't, there's some printing houses you can order your own through. https://www.thingiverse.com/thing:4148768
Edit: Someone asked me on FB about this so I figured I'd mention it here - apparently, some people would like to buy some from me. If there's enough interest, I may run up a batch!
peterm1
Terrific, great idea. I love it.
But it does rather make it look just a tiny bit like a pirate.
p.giannakis
Pan Giannakis
What about the rangefinder patch? Maybe there is in updated version coming?
retinax
Sweet! I simply keep mine in a bag or cabinet most of the time.
If you're at making gadgets for the Canon 7, have you thought about making an accessory shoe? Now that would be something I'd want.
comp_wiz101
Compulsive Tinkerer
I have mine out on a display shelf, so...
I've thought about the accessory shoe, yeah. Having looked at the original accessory, I've been thinking it may be a bit ambitious for my skills at the moment though. I have considered a "mini shoe" that only ties to the flash bayonet though... hmmmm
CarrotRoom
Nice. I was working on that for mine but had some design issues and life's just been too busy to finish it off.
What material did you use?
retinax
It could attach to the flash bayonet, and when attached, rest above the rewind crank and have some sort of feet that rest on the top plate around the rewind crank. It would need to be slightly flexible if it's just one piece.
comp_wiz101
Compulsive Tinkerer
The cover? Just some black PLA. Threw it together with Tinkercad, some real training wheels stuff
My first print was actually just a simple square, but I didn't like the extra corner fouling on bigger lenses
comp_wiz101
Compulsive Tinkerer
Yeah, I was thinking something like that. I'd probably start by modelling the bayonet and then going from there.
charjohncarter
Don't you just love it when some comes up with something that should have been thought of 60 years ago.
EDIT: My only remaining Selenium cell camera is a Petri 7s. It has a lens cap that covers the cell. It still work perfectly, so you may be on to something.
davhill
Canon P
My first print was actually just a simple square [rectangle], but I didn't like the extra corner fouling on bigger lenses
How’s it attached? Adhesive? Or is there a third dimension to it we can’t see?
comp_wiz101
Compulsive Tinkerer
The metering cell sticks out from the front of the camera, so the cap is a gentle friction fit over its frame
davhill
Canon P
Ahhh. NOW. It’s clear. Superb.
I almost wish I had a 7, just for this 🤣
paperino
Tks a lot for the idea, I just did one buy a printing house, very useful!
twvancamp
Thom
Looks great! Maybe we need a thread for 3D printed accessories?
Your modeling skills are streets ahead of mine, but I enjoyed learning some of the software when I made this adapter for my Oly35rc. This camera has a totally inaccessible aperture ring, so I designed this rough little tab.
comp_wiz101
Compulsive Tinkerer
This fine individual has beat me to it! https://www.thingiverse.com/thing:4217097/ (They also made their own meter cover, but I won't judge
retinax
Well I've simply stuck a shoe from a donor camera to my top plate with double sided tape, still beats that thing in elegance and practicality
comp_wiz101
Compulsive Tinkerer
Well I've simply stuck a shoe from a donor camera to my top plate with double sided tape, still beats that thing in elegance and practicality![]()
I rather like that it manages to duplicate how the original accessory holds the shoe, but doesn't cover up anything on the top deck. It pops on and off pretty easily too.
retinax
Looks to me like it does cover the meter readout. If I accept that, I can even position my stuck on shoe very conveniently, right now it's in front of the frameline selector... It is not that secure of course, I'd be worried about my finder if carrying the camera a longer time. So it's cool someone designed it, I might get one printed at some point!
comp_wiz101
Compulsive Tinkerer
Here you go - I took a quick snapshot of mine to show the view from up top:
Having the finder in the shoe does tend to block the window - a fault shared with the original:
https://www.flickr.com/photos/ngminchai/5799579195
I suppose it wouldn't be *too* difficult to add a shoe to the area on nearer the rewind crank - so long as you aren't worried about parallax
