EsaS
Hi Russ
Just like you said, in many cases metering every shot takes too much time. Normally I use a procedure something like Doug descibed. Taking readings in advance and trying to estimate correct exp. when time to shoot works mostly fine with negative film. Slide is a more complicated matter and with it I try to use meter more frequently, unless taking several photos in constant light.
Cheers, Esa
Cheers, Esa
