iiig frame lines and glasses
jmcd
5:29 AM
Anybody here use or has tried a iiig's viewfinder with glasses? Can one see the frame lines at a glance while wearing specs (I can just on the M3), or must one peak into the corners with a rolling glance to see the frame edges? Thank you for your replies.
I wear glasses. There's a lot of space around even the 50mm frame line in the IIIG's finder. Thus, there is no problem viewing the entire frame. There is also the added benefit of parallax correction. I would say that the framing is very accurate to boot.
