Ilford Pan F 50 - what to expect
ChrisN
Striving
1:30 AM
Canberra
I just bought a bulk roll of Ilford Pan F 50, because it was half-price and I've used up my last bulk roll of HP5+. Now obviously this is a pretty slow film, so I won't be using it for low-light applications, but what should I expect from it? Any tips or things to avoid?
I been using it almost as experimentation. I managed to get some grain out of the film by push-processing and using warm water in development.. see here: http://www.rangefinderforum.com/forums/showthread.php?t=24059
but also below are two properly developed images. You can see the midtones and even contrast you can get with a bit of fluke, i mean, concentration
No offense Ash, but the contrast on the one on the left seems pretty high.
Which leads me to my advice..Pan F is quite contrasty. Very low grain, and you'll probably need to shoot it closer to 30 or even 25 depending on developer, but very contrasty. Be careful of your development time and temperature. Of course, it's also not tech pan so it's not terrible with which to work.
allan
allan
Why the need to shoot it at the slower rating?
kaiyen I'm a little confused at your response. My results have varied because I have altered the developing for the results I wished to get. Those two images are from the same roll of film. And you can't see grain in the second image. I was posting to show the different results you can obtain.
That seems to imply that contrast is relatively controlled in your examples. I am saying that the one on the left seems quite contrasty to me, which is indicative of the nature of the film. I apologize if I misinterpreted you, but the point remains valid nonetheless.
I find that Pan F loses speed in most developers, meaning that you will not get the desired shadow detail if you shoot it at 50 unless you develop it in a speed-enhancing developer. I shoot Pan f at 30 if I'm spot metering and 25 if I'm average metering.
allan
Oops - I should've mentioned that those speeds are in Rodinal, though I don't adjust by much for D76 1+1, either. FX-39 gave me an honest 50.
allan
In DD-X it's about ISO 40, but close enough to 50. But I've got some exposed and ready for some Rodinal 1:50 or 1:100, stand development.
The DD-X negs looked quite good, but I want to try the Rodinal coax the maximum out of the emulsion.
OK - thanks again. I use DD-X and would plan to try the first roll at 50asa and the standard 8 minutes recommended on the spec sheet.
Now humour a novice here: to get the best neg for scanning - I have heard that a "thin" neg scans better than one too dense. To achieve that would I shorten the time in the developer, or lengthen it? I'm assuming that a thin neg looks lighter than a dark negative.
Shorten it, but I can't say by how much; you don't want to have inadequate highlights. Maybe up to 10% less, but don't go any further ... that's just a guess. I'd rather have too much contrast than have a weak negative, whether for scanning or printing, but I'm not a scan wizard, either, so I may be all wet.
I'd have to look at my PAN-F/DDX negs again, but shooting a few frames/bracketing at 40 might be a good thing.
Trius - thanks for the hints on the dev times.
Stevew - checked the shots in your gallery and am very impressed with the results. The CV35/2.5 is a fairly contrasty lens - do you get similar contrast with other lenses? Love the "Bell" shot especially.
cv35/2.5
cv35/2.5
The lens is contrasty but I wouldn't call it a bad quality. The scenes I shot were very contrasty and were well handled. I would not think the lens would be the best for available light shooting where alittle bit of flare fills in the shadows. I'm very impressed with the lens.
My Pan F shots have always been a little low in contrast, indicating that a little more development is needed for my set up than was indicated on the box. It is interestnig to work with a film that has such speed limitations and a reminder tht 400 used to be a super-speed film. You can use larger apertures for work outside. Post some examples when yuo get a pic you like.
good luck
Ben
Here's a question for those of you who've used this a bit: Where is it's color sensitivity? I use HP5 and FP4 as my primaries, and for my preferences have to use at least a med. yellow filter as those 2 seem to be pretty sensitive to blue (sky) - or is it in-sensitive to blue? I don't get much density/contrast for outdoor scenes, esp. clouds etc. What can one expect from Pan F? Sounds as though it's a bit less of an issue as it's already a contrasty film...
I too just started playing with a 100' roll of Pan F. Developed in Rodinal 1:50 shot at ISO 30. The sensitivity cuts off very steeply at 630nm and is zero at 650nm... according to the Ilford spectral sensitivity chart (using 2850 K tungsten light).
