imperial 200mm lens info
caila77
7:58 PM
Italy
I've a lens exactly like the one you can see here
the lens has an adapter ring at the base that allows it to be mounted on cameras with an M42 bayonet. The only problem I encounter is that there is no mechanism that closes the diaphragm to the set value nor is there any mechanism on the back of the lens. I can imagine it being a special purpose lens.
This looks like an old pre set T mount lens--you manually stop down the lens just prior to taking the picture. The T mounts could be changed to a variety of camera mounts and since there was no diaphragm automation these could function on many different cameras. When I used SLRs with stop down metering, I would focus and compose and then take a meter reading and click the shutter. After taking the picture, I would then open the diaphragm to set up for the next one. Since these lenses were mechanically much simpler than auto diaphragm models they were correspondingly cheaper.
