kshapero
South Florida Man
I have used him many times. Had an M6 which was not working in the slower shutter speeds. Sent in on a Monday. Came back to me the next Monday done!!! Highly recommended.
The camera was taken apart by someone who was inexperienced, the PV tension spring lost during reassembly, caused the frame line change problem. He also put the pressure spring for counter disc under the counter disc, which should go under the top plate.
CLA'd, cleaned and lubricated mechanical parts, the light baffles fell off by a touch, reattached. Adjusted shutter speeds, shutter works well at all speeds now and winding is smooth. Replaced PV tension spring to new, adjusted preview lever base holder to proper position, preview lever works well now and frame change is good. The rangefinder was quite hazy, cleaned and it is clean and clear now. Adjusted focus. The vertical alignment is good. For the counter disc, I aligned it and made it better towards to the arrow. The strap lugs have very light wear, but far from the time needs replacement.
Now, when I read an ad with "serviced by youxin" in the description, I definitely stop. I wouldn't touch anything services by him with a stick.
Ned, where do you send your cameras for CLA/repair instead?
Keep in mind, he is self taught. He is cheap for a reason. Nothing beats a Leica-trained technician.
