Leica LTM In trouble with my Leica IIIf
acanalda
5:01 AM
Hi to all,
Suddenly the main speed dial of my Leica IIIf became completely "mad". I can turn it even without wounding the shutter. The dial turns but it seems to be "disengadged" The shutter release button works and the shutter operate but I don't know at what speed. :bang:
Any suggestion? :confused:
Regards,
Arturo
As Fred has said the grub screws have probably come loose. Tighten the 3 screws and find B then loosen the screws and turn the dial to B and tighten.
Fred, Colyn,
Thanks for you reply. You're right. I have loose the 3 screws. So I can't tight them. The nightmare starts searching those kind of screws.
Regards,
Arturo
How can you loose three screws at once? Probably two were already gone and you lost the last one now. A willing repairman will be able to send you three replacement screws so you can fix it yourself.
