colyn
ישו משיח
When out shooting with your meterless RF do you prefer incident or reflected light metering with your handheld and why??
FrankS said:You should learn how to use either, then it doesn't matter. Either way requires interpretation and thought on the part of the photographer in order to get a good exposure.
Read through this thread for more info on this topic: http://www.rangefinderforum.com/forums/showthread.php?t=11120&highlight=chasing+needle
RayPA said:With incident I usually need more than one measurement (looking for the range). With a reflective in camera meter one is usually enough, but I'm always moving the f-stop ring with both. I think I prefer incident, though.
FrankS said:I'd say it simply boils down to personal preference. That, and what meter is handy at the moment.
colyn said:I usually find that when using incident one reading is enough because you are reading the light falling on the subject but with reflected I take more than one reading to determine a middle range between the high lights and darker areas..
In general I agree with the philosophy that it often doesn't matter too much, but learning how to use both is quite important. I'd amend Frank's words only slightly... I'd say "... , then you can choose which to use."FrankS said:You should learn how to use either, then it doesn't matter. Either way requires interpretation and thought on the part of the photographer in order to get a good exposure.
MartinP said:I can't be the only person who often takes "incident" readings by TTL metering off my palm....
but often your palm is very handy (sorry, couldn't resist it).
MartinP said:I can't be the only person who often takes "incident" readings by TTL metering off my palm, in similar light to the subject ? Just add 1/2 a stop, or whatever value you have previously worked out using a dual-purpose meter. It is very, very fast and reliable (assuming you have two hands of course).
All the usual stuff about your location/lighting vs that of the subject, and the reflectance of the subject needs to be considered too naturally - but often your palm is very handy (sorry, couldn't resist it).
