Industar-22 lens hood
If anyone is interested in the real thing,
there is a Leitz fison shade listed on the
bay #270360776442
Wait 'til you see the asking price!
This might be of interest. The other day I picked up what I thought was the lens hood to a FED and found it was a little plastic tub that some chocolate stuff came in - a dessert the grandchildren will kill for.
It looks adaptable to a lens hood using a sharp knife and making it slightly bendable with hot water. So here it is:-
The FED (KMZ) lens hood is on the right btw...
Have fun. Regards, David
Here's my home made solution for the Industar 50 :
Piece of plastic tube painted matt black inside and airframe silver outside.
And the Elmar version on a Spectron yellow filter :
Interesting solutions... Unfortunately I can't use the Industar-22 on my Fed 2 because the flange (screw) has a thickness too small and the focus ring does not arrive on infinity. There any solution?
The lens mount of some Fed 2 camera's is too flat to the body of the camera.
Option would be a Collapsible Fed lens with the 'piramid shaped' infinity lock without button.
In most cases the I-22 fits properly on the Fed 2. I've seen many fit properly, but mine doesn't fit the I-22 good as well.
Valkir1987, thanks for the tip. I recently purchased this Iindustar-22 just for the Fed 2, but I will have to use the Zork K-4...
