I agree that your best bets for the IR effect are Maco 820c and Kodak HIE. I've experimented with both.
Halation. Maco has an anti-halation backing, which subdues the "glow" or "diffusion" effect that is apparent in Russ' photo posted above. It is caused by IR reflecting inside the camera and hitting the film again. If you like the effect, HIE is for you. If you don't like it, the Maco is a better choice. With Maco, they recommend a 1 minute pre-wash to dissolve the backing. And it's almost impossible to load on a plastic reel because of the somewhat sticky backing -- stainless steel works ok. HIE is a bit thick and not a joy to load on a plastic reel either.
Filters. With Maco, the dark red B+W 092 (wratten 89B?) filter gives the best results; the opaque 093 (wratten 87?) cannot be used. For HIE, either filter can be used, but the 093 gives the best IR effect.
Grain. Either film is grainy no matter how you develop. HIE is a bit worse in this respect. If you don't like the grain, you might want to go digital:
http://www.irdigital.net/. That's a bit expensive, however. I've also tried IR with the Leica Digilux 1 and 092 and 093 filters. The filters cut out so much light that hand held shots are almost impossible.
Exposure. Meters provide only an approximate starting point, as they don't measure IR. And you can't see IR. Bracketing is called for until you get considerable experience or anytime you think you might have a "keeper". With Maco and 092 filter, I start with 1/60 and f 5.6. With HIE, about the same with 093 filter, but 1/125 and f11 for the 092 filter. There's more good advice at:
http://www.cocam.net/CoCamWS/Infrared/INFRARED.HTM
Will post some examples in the next frames.
