wpb
First, the shutter button should have about 1/8 of an inch play; even with the camera collapsed. It should be able to be pressed down and then return as there is a spring in the camera body. Next there is a long metal rod that runs parallel to the film plane and it has a 90 degree angle near the bottom of the camera. It is actually two pieces of metal joined by a rivet and it looks like a "L". This then lifts up on a metal bar that runs parallel with the bellows. If any part of the linkage isn't working properly you'll have a problem. One of the most common problems seems to be the last piece that is parallel to the bellows... it gets caught under the silver shutter release on the lens when the camera is opened causing it to push up (rather than down) on the shutter release. Looking from the front of the camera, the linkage should be on the left side of the silver shutter release on the lens.
Upon further review... you could also be pressing the shutter button and making the last piece of the linkage slip under the shutter release on the lens (after it has activated the shutter). You may need to rotate the lens slightly to adjust for this if it is the problem. If that is the case I can provide instructions.
