ampguy
I can't really do a completely accurate comparison with my other 2 cameras, because the ql17 giii has 40mm lens, and my digital has zoom, which covers 40mm, but I've just aligned by objects at l/r, top/bottom, and that's how in my previous thread sort of calibrated or decided my canonet matched my digital, whose exposures I was happy with.
Now I tested the digital and canonet, (again, approximating same focal length with objects and light position/amount) which match, with my SLR.
My SLR's meter is about 1 f stop smaller at dead center, but slightest off center it quickly moves to 2 stops smaller, indicating a small spot area is used for metering, while the canonet, and digital (digital has 3 modes, full frame, center weighted, and spot, I think I used spot to compare with canonet and get same metering). The SLR meter moves in an out of "green" by 1-2 stops as I move up/down/l/r, while the Canonet meter fstop only moves around by 1/2 to 1 step as I move about the same direction when metering on an indoor light w/ white wall behind.
I corrected for same ASA's, and checked battery voltages, and I'm fine with these differences, I know they all take good pictures, but I'm thinking that I might want to overexpose on the canonet 1 EV if my current roll of new ASA print film comes out grainy with new 200 print film at "normal" center weighted or whatever weighted metering the canonet does, per suggestions from others here.
Anyways, is it better to learn using a spot meter, or center weighted, to ultimately get to the point of not needing a meter. I mean I don't need a meter now, I can just do sunny 16 and bracket, but to get really good. How do other cameras meter, by spot or center weighted?
