Gabriel M.A.
My Red Dot Glows For You
High ISO is to HDR what water pitcher is to monsoon season. A link can be found, but you cannot compare one with the other. Unless, of course, you throw storms in teacups into the mix.
I don't understand your comparison.
Well used, HDR combinated with the post-processing of raw files is a way to moderate contrasted pictures and enjoy a better dynamic range, exactly as zone system with film - in that case, we're speaking about process.
For exemple in the image below I used HDR in the PP :
High ISO is just about technical specificities of the sensor - I think in future years we will see new sensors with very usable raw files @ 6400 ISO - I mean on most of the cameras in the market.
Here, we're speaking about technology - then the use of high iso depends of the needs and the choices of the photographer.
Methinks a lot of people make the mistake of thinking that tone mapping is HDR. The creation of HDR images is not about colour. It's about compressing the dynamic range. Not the same thing. Problem is that at the same time as HDR compresssion is done, blending is also done and it is the blending/tone mapping which is producing what people don't like and not the HDR compression.
Same goes for HDR photography. What on earth do people think photographers were trying to achieve with compensating developers and burning/dodging - compression of dynamic range?
+ 1
I'm not sure Thardy read carrefully and understood what I wrote 😱
I totally agree with what you wrote. Just pointing out the knee jerk reaction against HDR on photo forums by some people. These same people proudly post terrible looking extemely high ISO images.
I'm pretty sure what people are referring to as "horrible" in this thread is *extreme* HDR, where the scene becomes unrealistic-looking, like a depiction of a nightmare.
The *moderate* kind of HDR which, if executed well, won't be realized by the viewer other than making the scene look better. This is what I think is comparable to dodging and burning on the enlarger.
But Thomas Kinkade kitsch visionary extraordinaire was ahead of the curve. But say what you will, I'm sure he cries all the way to the bank.
As a relatively new technique, HDR is bound to be over-used. The novelty will wear off. High ISO, on the other hand, is maybe the most useful tool in the digital capture bag-of-tricks: Done correctly, it draws no attention to itself.
Done correctly, HDR doesn't draw attention to itself either, no more than dodging and burning did when done by a competent printer.
I guess HDR is a bit like razor-thin depth-of-field. Done correctly and sparingly, it can add to a picture, but by now it's gotten mostly ruined, because people post too many pictures all the time where it jumps at you because it was used as a visual gag, to distract from the fact that the picture doesn't really show anything.
