Is soft focus unavoidable with hyperfocal shooting?
Ming Rider
Film, the next evolution.
4:32 PM
I like shooting hyperfocally for speed, but most of my shots have a softness to them, which I like in a way.
But am I doing something wrong, or is this the way it is?
Example pic' below :-
Hyperfocal focus means putting everything in a zone of 'acceptable' sharpness between infinity and a given closer distance. The 'given closer distance' varies with (a) the aperture and (b) your definition of 'acceptable'.
Zone focusing -- http://www.rogerandfrances.com/subscription/ps how zone focus.html -- is usually a MUCH better idea than hyperfocal distance. From the URL quoted: Focus is not an absolute. There is always a zone either side of the focused point that is acceptably sharp. The size of this zone will depend on how far away the subject is; the focal length and aperture of the lens; the size of the final picture; and what you regard as 'acceptable'.
Thanks indeed Roger. The link was most helpful and made me realise that all this time I have been Zone Focussing. What a dumbo. :)
The example picture for, err, example would have been f8 with the subject at a distance of about 3 meters and focus at a distance of about 3.5 - 4 meters, so he should be approximately in the middle of the 'sweet spot'.
You're welcome. Should be sharp, then. Other possible factors: camera shake, soft lens, focus error, scanner problem (if scanned). Test with static subject(s) & tripod? And magnifier on neg?
Hard to judge sharpness from on-screen images.
I think part of the problem could be my poor distance estimating skills, compounded by myself being a metric guy and the lens (Serenar 50 1.8 ) being Imperial. It can be quite a pain in the proverbial carrying out 'on the fly' calculations in order to catch that unexpected opportunity.
I tried using this as an excuse for buying a CV 50 1.5, but the wife wasn't convinced. :(
Seems all my photos are soft. I blame it on my poor eyesight:D Ming I enjoyed looking & reading your blog...good stufff there!
That is a bar steward. But if you reckon metres = yards, you're only 10% out (metre = 1.09 yards) and 3 feet/metre is OK. Better still 3.3 feet = 1 metre, i.e. feet divided by 3 and (if you have time) +10%. Thus 16 feet = near enough 5 metres.
Old army training: visualize close distances in terms of 6-foot squaddies standing on one another's heads, or (more probably) lying down drunk head to foot. Or use 2m (VERY TALL) squaddies. For longer distances, use cricket pitches: near enough 20m (actually 20.12 m -- sorry, no help for colonials here).
It is a lot harder to zone focus with 50mm lenses than with wide angles. May be an excuse to buy a 28mm or 35mm lens. :)
Kevin - I second gb Hill. I like what you see and I like what you say about what you see. And I like the sound of your wife. The nearly perfect woman ...
And thanks to Roger for the tip about the cricket pitch. When I held a bat long ago it seemed the most terrifyingly short distance, but I think I can still guesstimate it and that should be a real help in setting the distance scale.
I can read all writings and recognize it's a man not woman - you call it soft? Not a problem as long as you aren't going to blow it up - but in normal cases blowups are seen from larger distance than small prints so total is the same.
In the sample photo, your focus point is much closer than the primary subject.
What camera? If you're focusing by scale and the focusing scale is inaccurate, you need to determine how inaccurate and adjust your focus settings to compensate. You should run a set of measured tests to determine the focusing scale accuracy.
Agricola,
Thank you for your kind appraisal of the blog. I'm pleased you like my writings and pictures.
Yes, the Misses is 'almost' perfect. If it wasn't for her bloody horses, or the lack of a CV 50 1.5 :D
What shutter speeds do you use most often?
My favourite tends to be 125th if the light is typically British, or 250th if it's slightly less grey.
If I have time to focus for the shot, I can go up to 500th cos' I can use a wider aperture, like f2.8.
Godfrey,
I use an M5 with a 50 1.8 all the time, so I should know the lens like the back of my hand. Unfortunately, I don't.
I will definately get the 30m tape measure out and do some test shots, but I really could do with a metric lens scale.
I wonder if there's a work around, like a quick reference chart taped to the top of the camera, showing metric converted to imperial to match the lens?
From my experience of street shooting results, that the shutter speed is far more important than accurate focusing, unless you are using really long lenses. Try to shoot at no less than 1/1000 and set the lens to infinity, then use whatever F stop is dictated by the light and see the results.
No disrespect intended Mfogiel, but if we had 'Cote d'Azur' weather in the UK, 1000th would be a reality. Sadly, if I tried that shutter speed, 99% of the time my pic's would be pitch black.
This somewhat contradicts both common experience and common sense. WHY infinity? WHY 'no less than 1/1000'? I've never seen such advice from anyone else. There is probably a good reason for this.
