Canon LTM Is this a big problem? Repair opinion requested
What would worry me about it is that it could easily be the result of a botched DIY repair (such as turning up the curtain tension too high to compensate for a dirty shutter.) I'm sure it could be fixed as long as there are no broken or missing parts, but it might fall into the category of "overhaul" rather than "CLA."
But then, I could be completely wrong, and it could need only an utterly trivial fix. In a gambling mood? That's pretty much what it comes down to...
That is the kind of feedback I am looking for, thank you. Most of you guys know more about repairs and problems with cameras than I do.
i saw it first!
essex has a complete curtain replacement for 130 or 160 bucks, can't remember.
factor that in as a worst case.
110. for a cla...
joe
Deal!
I feel like we are on Survivor, an alliance has been drawn!
I am not going to bid too much though.
You saw the issue with the rear element of the lens right?
it's a black dial p. (film reminder dial)
older version and for some unknown reason, i like them better.
a p in nice shape i would pay 325. if i really wanted it 350.
joe
There are a couple of reasons a curtain will hang up into the film gate area. The curtain was installed or reglued in the wrong area of the roller blind (easy fix if the problem is with the first curtain, just reattach the curtain straps a little bit over on the roller: second curtain requires removal and reinstallation of the curtain). The other reason that comes to mind is the roller blind is off by a tooth (happens when someone removes the bottom shutter cage and gets the gears out of time, just requires disassembly and retiming). The P is a pretty easy camera to work on. You might want to consider attempting the repair yourself.
backalley photo said:
i saw it first!
factor that in as a worst case.joe
They have Canon stainless steel curtain material?!?!?
7 REPL SHUTTER CURTAIN 160.00
i may have spoken too soon. it was for the 7. but they use the same curtain, no?
joe
joe
Joe, you could get E+ one for 324$ from Adorama... Or, maybe you talk about Canadian $...
E+=Excellent + Very clean
E = Excellent Shows normal wear, might have minor scratches, glass clean.
E - = Excellent - Average wear, may have small marks but no brassing
I would buy it, but I prefer LTM Leicas...
Joe- Would you really think that a Mint 'P' black dial with 50mm/1.8 is worth $350US?
Stu :)
Darn, just figured out that I will be on the train heading back home at the time the auction ends... looks like I am out on this one... good luck guys.
no, talking about american dollars.
that a good deal at 324, i think.
right now, my plan is to get my bruised p repaired. i will buy another p if i HAVE to but i'll wait to see what the repaiman says first.
joe
i was talking about body only.
i paid 275 and 300 for my 2 bodies.
joe
Ohh...
Checks out certain local auction again
So $500NZ for a mint 'P' + 50mm/1.8 is a good price then.
If I was bothered to actually take it out and use it, I'd buy it. But as per normal the 500c and M2 are hogging all the glory right now...
Stu :)
