Is this a Genuine Leica..link inside
arbib
11:53 AM
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310120790170&_trksid=p2759.l1259
I think this is a genuine Leica...not sure on the covering though.
1) Rewind knob (Diamond cuttings full length of knob)
2) Plunger Sleeve (Proper Leica design)
3) RF housing Height (LOW)
4) NO sync (No sync on Leica II)
5) no flash sync adjuster under SS dial (no Sync..not needed)
6) Lens has nail tab f/stop adjuster (FSU's have the ring f/stop adjuster)
Check out his Store.. he has a another Leica which I know is an FSU FED 2c
http://cgi.ebay.com/ws/eBayISAPI.dl...rms=algo=SI&its=I&itu=UCI&otn=40&po=LVI&ps=54
Diffenenty FED 2c
I have never seen a FSU copy that was this detailed...Typicaly it is a straight Fed 2c with Leica engravings, sold as "Perfect Leicas"...but no body parts replaced, just the engravings..
SO, Russia REALLY made "Perfect" copies over and above the so called "Perfect" copies??
It's a pity that these guys spend so much time and effort to get these cameras looking like that.
I think they'd be better off spending that same time and effort on making the original FED/Zorkis work right.
Anyway, is it worth it when you can pick up a real Leica IIIc for 250 bucks?
Do the Early FEDs have a ROUND RF sensor,, OR wedge...The Seller just wrote me saying his has a ROUND sensor. So he the ended auction to research abit more
by "sensor" do you mean rf arm cam ?
if so, the early FED cameras had a rounded cam, smaller and way different than what was on a real Leica or a japanese Leica copy.
Later Feds had the typical FSU wedge cam.
you can see what this early FED cam with the rounded end looks like on this site.
http://sovietcamera.110mb.com/fed1/
