Brad Bireley
- Local time
- 9:12 PM
- Joined
- Mar 10, 2006
- Messages
- 921
Anyone know of one or what I could use?
Thanks,
Brad
Thanks,
Brad
ruben said:And the Iskra is definitely a camera to keep closed when not firing its shutter.
NickTrop said:... Instructions seem confusing when you read them on the web, but once you have the pieces it's self-explanitory and simple. ....
Joao said:I read somwhere that the Iskra was best kept open - I mean, when it sits on the shelf -and this is the way I keepmine. This was supposed to be better for the bellows health. Am I making a mistake ?? Thanks in advance for opinions
Joao
P C Headland said:The good news is that you really don't need a lens hood on an Iskra. I never bother, with either my Iskra I or II. If you have the sun close to the shot, say shooting into the high sun or with the sun low and off to the side, just rotate the camera so that the lens door is facing the sun.
The thread is 33mm. Filters can be found with some dedication, the best bet is to haunt the classic camera shows. I have a 33mm screw in lens hood that came with my Iskra I, but it vignettes.
The best option is to source some "series" filters and filter rings. You can use a series V to VI step up ring, as it will screw in - at least a thread or two (the thread pitch is different). Or you can get a series VI slip on adapter and then use series VI filters, hoods and accessories. The one you want is a "Series VI adapater ring 1 3/8 in. 35mm" This slips on, so it is much easier to mount and dismount. I use this for B+W filters (yellow, green, orange, etc.).
BTW, the general advice for folders is to store them closed. I've not had any problems with light leaks on Iskras myself.
Brad Bireley said:Anyone know of one or what I could use?
Thanks,
Brad
