pismo923
Yesterday I developed my first two rolls of film and ran into a couple of problems with both rolls. One of the problems is streaking marks on the film after drying. I am using Photoflo at the end of the wash and my fingers as a squeegee. The second roll was better , probably because I extended the wash time. I know that there is an active thread here on the subject so I will read it carefully and hopefully find a solution.
The second problem is uneven development of some of frames. I am pretty sure the problem resulted from not have the film properly on the reel and obviously those frames not spaced apart (overlapped) would be partially developed or not developed at all. I am using a cheap steel reel ( yes I know buy a Hewes) but I did not seem to have any problems loading the film when I was doing my practice runs. Is there a trick to loading these reels or am I just getting what I paid for 🙂 I am considering returning the reel and getting a Patterson reel and tank. Will this make my life easier or do I go straight to Hewes?
On the plus side, I had a blast with the whole process and two bad rolls are not going to deter me. I have seen some amazing work posted here and it really has sparked an interest in B/W. Unfortunately it has also sparked some GAS. By the way, the films were Delta 400 and HP5 developed (well partially developed 😀 ) in Ilfosol 3.
