J-12 for street photography
john341
camera user
5:25 PM
I used on J-12 recently on a Leotax. What a great lens for the price! My scanner is of dubious quality, but I like the picture of my grandaughter over mum's shoulder in Nicholson Street, Melbourne. Hazy day (well it is Melbourne) but great light for photography
I've got one in Contax/Kiev mount, and find it to be a good performer. It works well enough with my Nikon RF, but I recently switched it over to a Contax II.
Had a Black J-12 before, and shimmed it specifically for the Nikon RF. The DOF covers the error, but shifting the "sweet spot" made a visible difference in the images.
[ Had a Black J-12 before, and shimmed it specifically for the Nikon RF. The DOF covers the error, but shifting the "sweet spot" made a visible difference in the images.[/quote]
I gently tried fitting my J-12 kiev mount onto a Nikon s2 but there was some resistance. Is the problem only with the outermost rim or is the bayonet a problem as well? Can't afford a nikkor w/a and a j12 which fits would be good!
The Black J-12 that I had originally would not go onto the Nikon. The problem was the chrome ring over the bayonet mount of the lens. I think three screws held it in place. I removed it and filed it down a little. After that, it went on without resistance.
The 1960 Chrome J-12 I have goes on just fine. The trick is to "feel your way" on with the lens, and try to feel the hang-ups. A little filing can fix it. The first Nikkor 13.5cm F3.5 would not go onto my S3. I found one of the flages had been bent. Flat head screw driver put it right.
I gently tried fitting my J-12 kiev mount onto a Nikon s2 but there was some resistance. Is the problem only with the outermost rim or is the bayonet a problem as well? Can't afford a nikkor w/a and a j12 which fits would be good![/QUOTE]
it is with the rim.
it will put a semi circular clean scratch on the trim plate of your Nikon.
I have a J-12 for Kiev/Contax too. My favorite one.
Modest soft image lens in wide range is valuable.
Sad to say in against light, flare and ghost appears more than modern lens.
Had a J-12 with which I was happy, but stopped using it on getting an Ultron 35/1.7. Carlo Cruz of Manila should soon get the lens.
John341, going by the title of this thread: I imagine the lens will be good for what is called street photography. Could even manage without focussing each time.
J-12
J-12
Quite right, payasam, I think that the 35mm angle is wonderful for off the hip photography..I will try to attach an airport picture from last week (pardon the quality, my scanner is rubbish)
I know that I lucked out picking it up very cheaply but, close to J-12 price once you subtract out the value of the included M adapter-
The Canon 35/2 is small, fast, and VERY sharp.
The major problem with the J-12 is that rear element. A lot of cameras just can't take it, either in Contax mount or LTM. You cannot put it on a Contax IIIa or IIa. It fits on "many" Nikon RF's, but some filing might be required. And on LTM and M-Mount cameras, you need to be careful of light baffles and meters. A Meter stalk can get "hit", and some TTL meters get their view obstructed.
With all that stated, put a J-12 on a Barnack style camera and you are set. It would go right onto my Leotax D-IV. But then I would have to take the Simlar 5cm F1.5 off of it...
I end up shooting with the Canon 35/2.8 and now 35/2 for a compact setup. The 35/2.8 is "just compact", and much sharper than the Nikkor 3.5cm F3.5. Another low-priced 35 to look at.
On J-12's scratching Nikons
> it is with the rim.
That is the issue. Now, MY "Beater" S2 picked up very cheap has every scratch possible on it. EXCEPT the J-12 rim scratch, I polished it down. Just lay Sand Paper flat and use circular motions. Take just a little bit off of it. Consider it "Conservation of Inconvenience" or "Price vs Elbow Grease". AND if you really want it perfect for a Nikon, take off the rear module, unscrew the front module to reveal the Shim. Increase it's thichness by ~0.4mm or so.
(Okay- so Optics forum, I've generalized this to 35's for street (and other) photography)
I've used a Jupiter-12 nearly exclusively on a Leica M4 for about one year. See my flickr photostream for examples with it.
It gives the photos a certain classic feel, but also has a flare problem.
Check the "shiny-ness" of the aperture blades. I had that proiblem on the Helios-103 and Menopta 53/1.8. Took out the front section and blackened tha blades with a Sharpie. That Greatly reduced flare.
