Calzone
Gear Whore #1
- Local time
- 11:37 PM
- Joined
- Nov 11, 2008
- Messages
- 16,953
- Location
- The Gateway To The Hudson Highlands
If your SS leak, you have mismatched reels & tanks. Try matching up your set, then marking them.. I have a dozen over 50 years now. None leak.
The loader pictured is junk. the ones where you slide in and push the outer wrap to center are fine. There are revised design.
Jobo expert drum for 4x5 is the way to go when using Jobo.
Jobo is obsolete and parts are a problem although I heard it is restarting.
Nikkor SS and hangars for 4x5. Buy a special order hangar rack from Arkay. One item to lift and dunk.
Ronald,
My tanks I bought new from B&H and they came with plastic lids that leak, and are not mismatched. Leak might be an exaggeration, but basically they dribble.
From what I am seeing the JOBO expert system is really great for 4x5.
I also saw that ARKAY rack you mentioned for dip and dunk 4x5. Looks like the way to go if one has a darkroom.
Cal
