John Carter's technique
Thanks, guys. I appreciate the nice words.
Speaking of basic math, John, can I ask how you decide on the amount of Rodinal? These shots were from two rolls I developed in the same tank and I just arbitrarily upped the Adonal to 3ml from your stated 2.5ml per 500ml of HC110h. I'm not a big math fan but can usually muddle my way through given a formula.
Thanks in advance.
I just added Rodinal and liked it so I haven't tested. I felt, maybe wrongly, that it sharpened the negatives a little, and popped the highlights. I don't know if you did this but I only agitate (3 time) every 3 minutes or 4 minutes. That holds the highlights back, supposedly.
I followed your agitation method as well, John. These negatives do 'look different' to my eye and your description is as good as any. And now, I need to order some Tmax 100 like I've been planning for a while. A quick question? You use this on medium format as well?
