Thanks Brian
Thanks Brian
I asked because my J8 at min focus, the inner ring of the lens was already inside the lens body, and followed coupling down to .6m on the m8 (with shims).
I did take the lens apart today using your pdf instructions (took me a while to figure out that to unscrew it, it's not unscrewing the focus barrel from the mount, but the front aperture area thing from the mount/focus barrel.
Anways, took that little black screw out, twisted it a bit, and put it all back together, and while focus was ~.8m to full infinity with no shims, the aperture was stuck closed at like f16 or so.
So I took it apart again and after a bunch of twisting and turning stuff, I just couldn't get the aperture to open up until I inserted that black little screw.
So with the screw in I opened it up all I could twist, which I don't think is wide open, but maybe like f2 or 2.8 and put it back together. My goal was to try to get it all the way to 1.5 or more open, then close it all together, but it appears that where it is rotated when you lock the screw down will affect how much you can open the aperture.
I might have a different variant than the ones you have, because I can't see any way in which the outer focus barrel has any impact on distance other than moving the inner focusing thing. The inner element simply screws into the mount/focus barrel until it is tight with the aluminum shim in there.
I can see how you can cosmetically remove the 3 screws to align up the distance scale independently of actually getting it to focus closer, but that is trivial for me, I'm looking for functionality here, and don't have a screwdriver that tiny anyways.
I wonder if someone put some rare expensive element inside the cheap chrome '70s aluminum assembly and that's why it's not quite the same as what's in your pdf pictures and ones here?
There's also some cryptic hierglypics scribbled on various parts of the internals. Perhaps it's a pre-war prototype designed for the KGB or something (collectors - make offers!)
If you do not file down the mount, different cameras lose coupling at different distances. The Canon P will follow my modified J-8 all the way to 0.7m AFTER filing the mount. Without filing, most lose coupling at between 0.8m and 0.85m. The Zorki 3M can follow the cam farther in, as the "finger follower" is used. Cam following Wheels lose coupling more quickly than the FSU cameras. Best to file down the mount by about 1 thread.
