Just Bought an M6 - One Question
Simon: Mine has the .85 viewfinder and I assume has the TTL? Wish I had framelines for wider lenses, but I currently have my friend's Ultron 28/1.8 mounted and he said it's basically the entire viewfinder screen. The .85 does show the 35mm frameline, but apparently that's as far wide as it goes. I'm going to have to read up about all of this so I don't sound like a drooling idiot.
If I may chime in...
I picked up an adapter on the cheap off the evilbay from a seller named Kawagebo, or Kawamall, or some variation thereof, when I upgraded to an M-mount Bessa. Paid $19 for it, and it worked in a pinch. Not nearly as smooth as a Leica or Voigtlander, I'd assume, but it's doing the job for now.
Good luck!
The only problem I'm having so far with the new CV 28/2 on my M6 is that I have to take off my glasses to see the entire field of view from edge to edge. This is not a problem that it would be for some as I'm far-sighted. Oh, yes, and I have to reverse my ball cap or part of the bill will be in the picture! Found out about that the hard way.
