Bob L
Picked up a Kiev 4 that has developed a problem with the flash, after firing 2 frames the flash failed to work, the flash sometimes will fire all by it's self with the camera just seating there but will not fire when you push the shutter.
I put a meter to the flash circuit contacts and get a open until I fire the shutter and then get a closed circuit , the same my other Kiev4 ( which works fine) but still will not fire the flash.
Any idea as to how to correct this problem.
