TVphotog
Television Grunt
Okay, I have my Kiev 2. CLA'ed the sucker and did a bit of repainting. The first roll through, before the CLA, looked great. There was some frame spacing issues, but that was expected. The shutter though I believe to be the culprit of the spacing issues and not the advance fork as normal. The advance knob does two jobs in advancing and recocking the shutter. The first job/part of the turn is film advance only. The second job is recocking the shutter. This is where I run into problems. I can not for the life of me make the shutter 'mess up' with it out of the camera. Once I put the camera together the problem arises. About half way through the recocking of the shutter something stops either the shutter or the advance knob. If I back it up slightly it will continue on normal. The exposure following this looks fine, so it is not causing an issue with the actual operation of the shutter. On the frames that this happened it did cause the spacing issues. I am thinking that there is a screw that may be tightened to much or may be too long. Ruben and such, any hints or ideas as to the cause of this malfunction.
TIA
Ken
TIA
Ken
