Kiev stiff focus at 1m
dpttool
12:10 AM
I just got a Kiev 4am and after detaching/attaching the lens i noticed that the focusing made a "jump" at aprox. 1.1 meter.
I can't recall I had this before detaching/attaching the lens (but I'm not sure), anyone knows what might have happened? the jump is there even if just focusing the helical without the lens attached.
probably there were particles of dirt in the helical and they just moved to the 1.1 meter mark. you will have to disassebmle the helical, clean/ and relube it. watch out for the correct RF adjustment. I'm sure somebody will give you a link.
Seems like major overhaul, not what I had hoped for...
That what I had for buying a higher priced CLA camera from sovietcamera.ua.com: Of course I had to mess it up myself.
If the focusing (rangefinder itself) has a jump, you just need to focus from 0.9m to the distance of 1m. The moving mechanism at 1m for the rangerfinder lens is not smooth.
Richard
pangkievrange said:
...The moving mechanism at 1m for the rangerfinder lens is not smooth.
Richard
It is the lens moving mechansim thatis not smooth on my camera. I'm not sure I understood you, do you mean that it isnormal that it is not smooth at 1 meter?
Anyway, I'm not going to disamble the camera myself for this. The focussing is very accurate as it is now and it is not a big problem that focussing is not supersmooth at very close distance.
Thanks for all good replies! It sure is a good forum for a Kiev newbie.
If the problem is with the rotation itself, can you overcome the bump by rotating? It's a big job to take out the helical thing. I have 3 cameras having a bump around infinity (20m or 10m) that will not affect the use. If I need to use that distance, I typically rotate the lens instead of the focusing wheel to overcome the resistance.
Richard
