Kodak Hawkeye B/W - Developing options
Johnmcd
12:51 AM
I decided to start a new thread concerning my recent use of Kodak Hawkeye surveillance B/W film. I now have the equivalent of 120 rolls ready for bulk loading so I am keen to develop a workflow that gets the most from this interesting film.
My first foray involved exposing it at 100 iso by mistake (http://www.rangefinderforum.com/forums/showthread.php?t=143569). I ended up with some flat, low density negs that scanned well enough.
I then exposed the next film at 400 iso and developed with TMax 1:4 at 5.5 mins which was recommended for normal contrast by the spec sheet. These negs looked identical to the first lot that I 'pulled' with Rodinal 1:50 also at 5.5 mins!
The image below shows a 'normal' density set of negs on the light box next to the Hawkeye negs.
I printed some last night in the darkroom and while I got some nice results I had to dial up the filters to contrast 5 equivalent to get some 'punch' in the print so it would look like the scan below. BTW, the film has beautiful grain and is exceptionally sharp.
This doesn't leave me a lot of leeway when wet processing. Therefore I would like to try and get a denser negative in the first place but without sacrificing grain size and sharpness if possible.
Any suggestions or developing combinations would be greatly appreciated.
Cheers - John
The only suggestion I can see from the information given is to increase development time. Stick with one developer and get it down before jumping between developers.
Since I only scan, and push Hawkeye 3 stops routinely, I don't know that I'm much help, other than to say that you can trust the pack info with times. And that means up to 3 stops, so don't be afraid to go further with your development.
If you haven't already, make sure your developer is still good (I think you said it was a freebie?) and your temperature correct. I got caught on that (with a different film and developer) recently, with negatives unreasonably thin even with extended time - I hadn't factored in that the developer was past its best before and that my tap water was now 17 degrees not its customary 20.
Thanks Scrambler. By pushing do you get a denser neg? Does grain suffer by doing so?
My developer is always 'good' as I use it one shot and never have the undiluted liquid for long. In this case it was TMax and one shot from a fresh bottle. Temp also is 20 (or certainly at the beginning of the time).
I don't really want to push it literally as I'd like to use it on sunny days. I'll expose at 400 iso but see what happens with extended development.
Cheers - John
Denser - definitely. And more grainy, though that I really can't assess because of the scanning.
This outdoors at 3200 (push 3 stops) - developed 11 minutes in D-76.
This negative looks about as dense as the Hawkeye you pictured above. It's pretty much spot-on for my scanner but it looks like you want a denser negative.
Petals away by Scrambler@4350, on Flickr
Hey John,
i got some hawkeye as well a month ago just got around to dev now, i found the results quite nice for the price :0 here some samples
exposed at 250 ish on Rodinal 1+50 15min at 18C 1 inversion a minute(not the best examples though :/
Thanks for the info Vitor.
I'd like to keep it at 400 iso if I could as I was very happy with the grain and sharpness. How dense were your negs?
John
Thanks. I'll keep experimenting. I have plenty of it to try with :)
John
