Konica Auto S3
wintoid
Back to film
12:09 PM
I found a working example of this camera and it arrived today. It has no lens cap. I need to either put a filter on it to protect it, or ideally to put a lens cap on it to protect it and to turn the meter off when not in use. I tried to measure the front of the lens, which looked like 51mm, but that can't be right, although I suppose the original cap was probably a push-on type, which would be ideal.
Does anyone know what size lens cap I need, or what filter size I should use?
The filter size is 49mm. I used a square Praktica wide angle 49mm metal hood for it. IIRC the meter is only activated when the button is pressed. More infos at the CQ site.
Didier
You're lucky. 49mm is a standard size for many filters and hoods. I use Heliopan 49mm round hood and filters for many of my compact RFs. I use Heliopan step-up rings to get to that size if not already.
The 49mm hood:
mounted on the S3 (it did not vignet, and not intrude much into the VF)
D.
Thanks for the info. Have ordered a 49mm Konica push-on cap from eBay, and hope it fits. I think I have a 49mm UV filter at home languishing on an old Pentax lens. Yippee!
