andersju said:
I did try a bit of cleaning, according to the instructions on silvergrain, and it did improve the situation but not much.
I am also the proud owner of a Konica Hexar black (the one with factory-enabaled stealth mode) and I just love it. I probably shot more than half of my B&W rolls with it and, in 15 years, the only problem I had was the shutter-button-issue. It had to be replaced, cleaning was not enough.
Apart from that, is virtually indestructible (several falls from waist high to concrete) and it has, IMHO, the best 35mm lens I have had (and I had a Leica 35 Summcrion ASPH). I'll post a few pics with it, as soon as I'm back home, because images are much better than words. But, be it on B&W or color slide, image quality is stunning. And it's the best "light-gathering" lens I've owned. I've wonderful pics inside churches, only lit by candles, with a 100 ASA slide film. Global contrast is slightly lower than the 'cron ASPH but detail and microcontrast are just unbelieveble. That's perfect for high-contrast, low-light situations.
Moreover, I can esily shoot with it at 1/15th and lower with no shake, the shutter button is very soft and the shutter itself has no vibration. On stealth mode, is my quietest film camera. I think I make more noise advancing the M3 lever than the Hexar does on stealth mode!
I still use it regularly (I don't have the guts to sell it and it kills me seeing it standing on a shelf) and it's one of the reasons why I sold my 35 'cron asph (that, and several very good CV lenses on the same focal).
If you like Tri-X on the Leicas, just try it on the Hexar... I even tried Tri-X+Rodinal and it's a killer combination on the Hexar: incredibly sharp negs, without the "britleness" you can get with the same combo on the 'cron ASPH (too much overal contrast).
The Hexar AF lens should be perfect on a digital body, such as the Epson or the M8. I know there was a version of this lens on L mount (
http://www.dantestella.com/technical/hex352.html) but it's almost impossible to find. I would buy one for my R-D1s.
