Konica X24 on a Fuji X? Trigger Voltage
DNG
Film Friendly
8:53 PM
Indianapolis, Indiana. USA
I just won a Konica X-24 flash, The main use is on my Nikon FM2n, but, I can't find the Trigger Voltage on Photo Strobe Trigger Voltages the X18 is under 9v, and the X14 is under 6v.
I also have a X100T that a larger flash is nice at times, but wanting a lower balance point than my Sunpak PZ5000 AF taller flash provides, and I am not sure of the max volts allowed before any damage can be done to the camera.
Has anyone with a Voltmeter and an X24 tested the voltage?
I do have a wein safesync hotshoe>hotshoe flash adapter, but, it adds more height and the lock screw doesn't only lock down a flash tight enough.
I am not sure of all the X-models, but the X-E1 can handle up to 300 volts (I asked Fuji a long time ago). Would be logical if the same applies to all X models, but better check with Fuji to be sure.
