Lab v Lens
Sorry to say, but this looks like burn holes in the shutter. Can you check your camera visually ? (Assuming you are referring to "The Rother")
If you only care about function and not re-sale, it's pretty easy and cheap to fix yourself with "liquid rubber". You should see the holes though ... typically a burnt shutter curtains (check both) has spots that look a bit golden. When you check against a strong light source you might even see the hole. Don't ask me how I know ....
