Learned Something Yesterday - A Happy Mistake
mmartin09
7:11 AM
So this is embarrassing, but also informative so I thought I would share it. Here's what happens when you accidentally grab the wrong roll of film and develop Portra 400 in HC-110 like its TMAX 400. I had no idea you could dev C41 as bw and get anything usable. It's not great, but its much better than I expected. I scanned it on my Epson V750 and did a 30 second levels adjustment in photoshop.
I've got over 300 12-exposure rolls of expired Fuji Superia X-tra that print with a magenta caste and must be shot at least 1 1/2 stops over. I think I'll save the CVS development costs and just develop it in Caffenol!
Oh my god!
That's amazing! I'm gonna have to try this for sure! I have a bunch of ****ty Fuji Superia 200 I really can't be bothered to shoot in color. Might shoot a bunch of 'em and just try B&W dev!
Rodinal is good for this
T400cn in Rodinal
Xp2 in Rodinal
T400cn in Rodinal
Xp2 in Rodinal
Those shots looks really good.
I've got six rolls of Superia 100 and 200 that I want to develop in Rodial, what time and dilution dilution did you use? Any other hints or suggestions you can offer?
Holy crap thats awesome. I had no idea. And the photo looks terrific!
Perhaps this is a new method of processing color at home? :)
EDIT: I assume the colors were messed up which is why you converted it to BW?
It does make sense though, because AFAIK, color film does contain silver, during the c-41 process, this silver is oxidized, which in-turn make the film release color dyes in the various layers.
The silver is then washed out, leaving the dyes behind, thus creating a color image.
By using a B&W process on the film, I suppose you'll end up with a somewhat faint/thin B&W negative...? (never done it myself, so I've never actually seen such a negative).
By that logic, this would postulate that one normally needs to overexpose a color film somewhat, to end up with a more normal negative after B&W processing it...it this correct?
Works a treat, done it often in Caffenol. As some have mentioned, dynamic range can suffer, especially highlights can wash out more readily, but I find mid tones can be rich and detailed.
Cheers, i mixed it 1+100 for 19 minutes 7 invertions every minute fixing seemed to take longer than conventional B+W, i really like how the XP2 turned out, here's another in the sun
The shot about was shot at iso200, the one below was on the same roll i uped the iso iso3200 (potter through window)
I thought I would share one more from the roll as I finally got back to it. After this little accident, I might start experimenting a lot more with this to do it on purpose. I'm starting to dig the look.
This is in line with what my experience was. I exposed as normal and had to really add some exposure in post to make it work.
