Leica 50 summilux pre asph PROBLEM?
Dan95
6:06 PM
Hi recently I bought a Leica 50 lux, second version. Had a filter on, and I tried to remove the filter. Instead, the lens detached from the barrel *too much force I guess
I was able to screw the lens back in. Is this normal ? Or should I be worried ? This also happened to my other 50 summilux v2.
And, when rescrewing the lens back in its barrel, do I need to follow any guidelines ? There are number etched in the barrel. I simply screwed it in till it cant be screwed anymore..
E43 pitch .75mm, "regular" 43mm pitch .5mm
If hood like XOOIM used all the time, it should have no problem to use "regular" filter.
