Leica IIIa spool
richardHaw
junk scavenger
3:36 AM
Tokyo
Hi! I was looking for a spool for my 3a yesterday and several shops told me that the spool for russian and japanese clones (or generic ones) wont work with my 3a. they told me that the diameter and length may be different and that will cause my film to get tangled at worst 😱😱😱 i cannot see that happen to be honest and the only thing i can think of happening is if the spool didnt match the alignment of the sprocket then the worst that can happen is my film wont be parallel to the film rails.
hoping for your expert opinion, i am currently overhauling a 1934 3a that I found at the junkboxes and i would love to make this work again, i even got a pre-war elmar for it yesterday.
I'm not sure about that... maybe? I use a pop-up Leotax spool in my Leica II and it works better than the original! Over the years I've heard of others using different spools for different cameras by choice or necessity. I think they are generally interchangeable...
I have a pair of Leica IIIc's that I use with Canon take up spools. I like the pop up knob the Canon spool has. One spool works perfectly, the other is more troublesome. The problem spool does not grip the film leader tightly enough and if I push it all the way in, the sprocket will not engage the film. I am getting used to it but clearly there are slight differences. Good Luck. Joe
Never had a problem with Russian spools,
I keep about 6, so I could quick load.
The only trouble is losing the skin off your finger tips dragging the Ruskies out after a roll.
+1 for Canon spools love the pop out knob.
Thanks, everybody!
I have overhauled (and made an article) a Nicca3s, maybe I can use the spool from that camera. I will try and see if I can find a cheap Leica spool and if I can't then I will just have to look for canon spools 😱😱😱
I see them all as interchangeable but out of the dozens (spools) I have there is just one odd one that won't fit them all (bodies).
I prefer the USSR made ones as they have that nasty looking but very functional hook to hold the film.
And, BTW, early Zenits had spools that were removable. And, BTW2, early USSR made ones were a copy of the Leitz one with a clip that fails, just like the originals do...
Regards, David
Uh. Did someone say something about a "pop-up spool" for a IIIa... From a Canon or Leotax? Might one fit a IIIc of IIIf with such a device? My fingers are fatter than when I was a kid and I have no nails to speak of...
The Canon spools (think IVSB) have a nice little pop out knob that peeks out from the bottom of the camera making them SO MUCH EASIER to remove. You can find them liberated from their respective bodies on Ebay.
I had the opposite problem with my first IVSB, it came with no spool! Used a Zorki spool and it worked fine until I found the right spool for a few bucks at a swap meet YEARS ago.
What interchangeability??? I have cameras with the following spool hole diameters:
Tower 45 by Nicca 8.7mm
Leica M5 9.2mm
Yashica YF 9.7mm
Leica/Canon 10.3mm
None of them interchange. There may be more sizes I don't know about, so be careful before you order just any old spool.
By the way, I need a Tower/Nicca spool with an 8.7mm hole.
Hmmm, I'm not sure there's a way of telling the FED from the Zorki spools as none I've ever seen have a make or anything to identify them I've them in brass, plastic and some white metal and with and without pull out ends but all with an 11.2mm* i/d.
I've just one with the Leica style clip and all the rest have that nasty looking but effective hook to hold the film leader.
Also, they get mixed up like lens caps. People often sell old made-in-the-USSR cameras without spools and who knows enough to identify the correct ones? It's like lens caps again...
FWIW, I've a 1936 FED that came with a plastic spool in it and a Zenit that came with a Leica style one in monkey metal, as we call it here.
Regards, David
* Most likely 11.15mm give or take 0.1mm.
here's an update: i just got the spring-loaded canon spool 😱😱😱
it was cheap so i just swallowed my pride and bought it 🙄
Since my post in January I've been looking at spools and cameras. It's very obvious with the Barnacks, FED-1's and Zorki-1's (and probably the very rare Zorki-2) that some take up spools will fit and some won't. So I was able to create two heaps of spools quickly and I have carefully measured 10 of them.
These are what fit the Barnacks, FED-1 and Zorki-1:-
The one on the left is a typical Leica spool; points to note are the criss-crossed knurled end and the arrow pointing to the clip. Not all of them have the arrow, btw. They all seem to be brass and some are painted and some blackened chemically. (The camera bodies checked date from 1926 to 1946.)
In the middle is a typical FED or Zenit or Zorki spool. It hasn't got the knurling like the Leica's and no arrow either but the clip is more or less the same. These and Leica ones sometimes have rounded corners to the clip.
Lastly, the one on the right with the nasty hook is from the old USSR and fits the Leicas etc but it's the exception. I had just two of them that fitted and dozens of hoooked ones that don't fit Barnacks etc.
As for measuring them; the Leica ones are about 0.024" shorter than the old USSR's ones. The internal diametres are the same but the clue as to their fit seems to be the diametre of the take up spools' slipping clutch post and its length. The ones that don't fit Barnacks etc all stick out too much for the bottom plate to close.
So the visual clues (for buyers) seem to be the clip's shape, knurling and sometimes the arrow. BTW, one of these Barnack fitting spools came in a Zenit from the 1950's.
I hope this is of some use. I wish sellers on ebay and so on would read this, they all think a spool will fit (say) a FED-1 and a FED-2 and so on and vice versa but the 1's are the exception. One of these days I'll start sending spools back...
Regards, David
Completely agree with David, I had a spool come from eBay recently and it's the type III he shows, my Leicas won't close with it installed.
Also, I had a Russian spool in a Leica before that was very tight, the botttom plate closed fine but the spool almost fused itself on the cameras spindle, I needed small pocketable pliers to get it out every time. In the end I bought said Canon pop-up spool for it and never looked back...
Erik, That question would be easy to answer with your camera and my hacksaw but putting the trapdoor back afterwards might just be difficult. I suppose you could take the cover off of the camera and experiment.
Regards, David
