Murdoc1905
The thread Ridge sticks out only 0.01 in (0.25mm) so probably as small as is printable, the diameter of the hole is 0.134 in (3.4mm) (roughly a #6 screw (4mmx0.7). The process used to 3D print it is the SLS which is better for printing accurately over standard 3D printing, but it also isn't perfect. I wanted to avoid standard screws as I didn't want it to take 15 turns to move the spool in and out but it looks like I might have to even just for testing purposes. I will probably opt for a threaded/melt in insert for now. Thou I imagine final designs would be made of aluminum so adding threads would be a lot stronger reducing the need for an insert.How small is "small"?
Sadly ya dont print yerself.
For "small" threads, speakin of threads below M6 I give it the lowest possible layerhight.
And because of the diameter, I'm drawing with Freecad and I hafe to give the threads a + tolerance between 0,3 and 0,4 mm, depending on filament type an layerhignt.
Or just print the core diameter of the thread and cut it with a tap?
Works well in PLA and PETG.
Or, depending on available space, press in a "melting nut"?
Just my 2 cents !
