Leica IIIb slow speed escapment
Jerevan
Recycled User
10:45 AM
Does the IIIb work in the same way as the earlier III/IIIa when doing a cleanup of the slow speed escapment? Or does it need to be further taken apart?
It's very much the same, the only difference in the IIIb is the viewfinder optics.
I cleaned mine without removing it from the body. Used lighter fluid. It used to stuck on lower speeds but its working now.
Regards.
Marcelo
Thanks, gentlemen! I'll see if I can sort it out eventually, it's the everyday camera that needs some work (1 second is a bit hiccupy).
To conclude - I got both the III and the IIIb up and running, with the nod going to the III escapment being a bit easier to get in and out.
I noticed that the IIIb escapment was differently constructed and with ball bearings in there as far as I could see.
They would be slightly different depending on the lay-out of the slow speeds on the dial.
The IIf apparently had a slow speed gear as well, to manage the 1/25th setting.
