True... but both suit you well too. I think the M-60 could be a nice camera if they make a layman's version. 🙂
True, but I'm not as deadly accurate as Andre and likely will never be.
A M-240 is a great camera, but I'm still trying to restrict myself to B&W only. Not sure if I need a color camera, and I think I'm going to promote pitch my next Leica camera.
The "Calzone MM-SS:" MM-SS is short for M-Monochrom: Square Shooter; or M-Monochrom; Super Sized. The idea is to make a 36X36 version of the Monochrom with some improvements like the bigger buffer of the M-240; the larger screen of the M-240; and a black paint version.
Much of the hardware to build the MM-SS could utilize parts that are already in production like say the top plate of a MM, 0.85 MP rangfinder assembly (with square framelines), M-240 bottom plate. Basically the size would be the same width and thickness of a current digital M, but it would be perhaps 3/4 of an inch taller and maybe the height of one of my film M's with a TA Rapidwinder. Don't forget the electronic framelines borrowed from the M-240.
A 28mm lens would be around a 50mm FOV for shooting the square. I can see me buying a 28 Lux to add to my 28 Cron. A 50mm would be like shooting a 90. Wide open the image circle on some lenses might have light fall off in the corners when shot wide open, but I'm thinking the image circle of modern Leica ASPH glass will likely cover the corners.
As far as sensor goes 36X36 has two possibilities: one is make a 16 mega pixel 36X36 sensor; and the other is make a 24 MP sensor. One offers a bigger pixel which has its performance advantages; the other with higher pxel count has its own merits. I for one would favor the 16 mega pixel for tonality and high ISO capabilities. I see the only real expensive cost here to develope is making a new 36x36 sensor. If a 16 MP sensor is developed then even the old firmware that is used in my MM can be mostly used.
Leica has the guts to create boutique cameras that fill specific nitches, but does Leica have the wisdom to create the first digital camera that shoots the square? My Monochrom remains my dream camera, and I can't see any big major improvements, but I think a MM-SS is the next best new idea.
I HOPE SOMEONE IN LEICA DEVELOPMENT SEES THIS POST.
Cal
