Leica M to LTM lens mount conversion?
cloak.dagger
2:18 AM
I was wondering if anyone has tried this.
I love my Canon rangefinders, but since there's no fast 21mm, I thought of converting the Zeiss ZM to LTM. If that's possible...
Any hints would be appreciated!
I would buy the ltm version Nokton 50/1.5 and save some money.
But the LTM version is overweight on a Barnack (52mm filter thread!), the M-mount version converted to LTM would be just perfect...
I dont think it would be possible using an adapter. Flange distance of LTM is 28.8mm and M is 27.8, because the M mount bayonet is on the way; it would involve removing the M mount, but who knows? there are lots of clever people around there 🙂
There are a number of older Leica lenses in M mount that are actually LTM lenses with a factory installed M mount. You can remove a tiny screw and carefully break the adhesive (by turning I suppose) to remove the M mount part, leaving you with the LTM version of that lens. In every case, there is a native LTM version of this lens that was also produced and sold, but because the native LTM versions were produced and sold in smaller numbers. Thus, they seem to cost more on the market due to rarity. Also, the M-mount versions of these lenses had markings on the barrel for closer focusing (often 0.7m vs. 1m on the LTM version). Meaning....a purchase of the old M-mount lens, then removing the M mount, and ending up with an LTM lens is a seemingly good value. I've only done this with the 35/2.8 summaron. I've seen 21/4 super angulons with this configuration. Have not seen the 21/3.4 with a removable M-mount though.
And, save the M mount. Clearly! It may come in handy in the future with either your own M-mount body, or if you sell said lens; a wider market of M and LTM users.
the fastest 21mm that comes to mind for LTM is the GR lens 21mm 3.5.
i would know, cause i have one in black 😀
