Hey all!
picked up a nice M2 button rewind and lens for a steal. It's clearly not been used in a while, with a stiff advance lever and hanging slow speeds plus capping fast speeds. My thinking is it requires a basic cla which should hopefully sort the shutter issues without the need to adjust the timings. Luckily the finder is perfect as are the curtains.
Im all tooled up ready to strip it. Having read a few of the online repair guides, a few questions -
Does removing the rangefinder assembly cause the assembly to "uncalibrate"? is it possible to remove it and mark settings in order to reinstate it as it was?
My aim is to strip as much as i need to in order to clean and lubricate necessary parts - however it would be great if I can do this without needing to adjust all the settings from scratch. Can anyone run through which mechanisms need removing that would then require adjustment on assembly?
the brake assembly; if i loosen it in order to flush clean it, does this knock the brake adjustments?
Im following this, walts post - teh first answer to the OP and also using the pentax guide and another repair guide:
https://www.photo.net/discuss/threa...rJYIGUOG3jhMT2ddHAUMc8OCgx1P4Gj5MqbXRiOzclHx4
Im particularly keen on his sentiments regarding a thorough cleaning and that it will most likely lead to no necessary adjustments; though now im aware that in order to carry out a sufficient CL, A might be necessary.
I am an amateur, though I do have some experience repairing barnacks. this is a rather more complicated animal but i have a strong desire to learn how to fix it. Any input is greatly appreciated!
