Keith
My point is that all this anecdotal stuff is simply useless. We're spitting into the wind.
What? .... I thought we were p*ssing up a wall!
Am I at the wrong event? 😱 :angel:
unless of course you prefer shooting with a rangefinder.
you know what, i'll never argue that the m8 doesn't have flaws. but it's the only real game in town for me.
Hopefully your Tilley hat fared as well.
More evidence of the superior finger control developed as a result of your previously mentioned Dentist training?
LOL!
No doubt those elephants saw that M8 in your avatar and figured you had kidnapped one of their calves!
:angel:
Ok, enough fun ...
You really should look at the credentials of the reviewer you try to impugn by referring others to "impeccable" sources. Mr Kamber has multiple Pulitzer nominations and other kudos - plus his shots on his site are outstanding.
the fact that NO DIGITAL CAMERA is as reliable as their film counterparts.
The fact is that digital is fun and often necessary these days however, to date no manufacturer has made a digi as nice as they made their films, which is why I always keep a nice brick of tri-x and an m7+m4 in my bag next to my m8.
At the very least anyone who purchases a $5,000 camera should expect perfect quality control. I know a lot of RFF'ers are not price sensitive; but, $5,000 is a lot of money. Arguments that the M8 is no worse than other cameras in QC seem to miss the point.
At the very least anyone who purchases a $5,000 camera should expect perfect quality control. I know a lot of RFF'ers are not price sensitive; but, $5,000 is a lot of money. Arguments that the M8 is no worse than other cameras in QC seem to miss the point. A small company hand building a $5,000 camera should be able to at least not put completely dead cameras and cameras having significant (and obvious) display or sensor problems into the hands of dealers. Leica has done both with the M8.
Even with a rangefinder, my aging eyes have trouble focusing manually in very low light. The M3 used to be my goto camera for those situations. Now I put an ST-E2 on my 5D and it will focus perfectly in total darkness. Now, if I just had ISO 20,000 so I could get an exposure in total darkness! I could have a whole series of black cat in coal bin photos. 😉
I've found my M8 to be completely reliable, but a good friend has gone through a number. My Canon D60 was terrible, and had to be returned numerous times for adjustment/repair.
At present I still have/use a 5D and 40D, and both have been as reliable as the M8.
With respect to the report on the use of the M8 in Iraq, there are a number of stupid items mentioned that detract from the main point; namely, that the camera is a dissapointment to him.
The lack of 21mm framelines complaint is just silly. This sort of stuff is easy to determine before you buy the camera, and then it's a non-issue. If he absolutely must have a wider than 24mm lens on the camera, and doesn't want an external finder, he should not have bought the camera.
Frameline accuracy is exactly the same on all M Leicas, the only difference being that since various lenses now focus closer the discrepancy at infinity is proportionally greater. At closest focus distance the framelines are accurate, the same for M8 or M3.
The bottom cover thing I find annoying as well, but I don't shoot (pictures) when other people are shooting (bullets).
The selftimer setting I find extremely stupid, and have similarly blocked it. I too think that the exposure compensation should be settable by rotating the back wheel. These are the sort of things that are typical 'first model' mistakes, similar to those by other companies.
The low light capability I find not that far off the capability of the 5D. The 5D can't focus well in low light, and I lose a lot of shots that way. I use the 35/1.4 and 24/1.4, and while the former is a good lens, it doesn't compare to the 28 Summicron, so I tend to shoot it at f/2 if possible. The Summicron I shoot wide open with confidence in the performance and in the focus setting. I usually don't go over 640 ISO, whereas I often go to 1600 on the 5D. If I want to get the same image at the same shutter speed, I underexpose the M8. The DNG's respond very well to this, whereas the 5D CR2's don't nearly as well. On the other hand, in bright light highlight recovery works much better on 5D files than M8 files. In any case, the low light performance of the M8 is fairly decent, and I often prefer to use the M8 over the 5D in bad conditions. The caveat is that you shoot DNG's. If you have Lightroom that isn't much of a handicap.
White balance is now better on the M8 than on the 5D.
All in all file quality comparisons between the 5D and the M8 indicate that with good lenses, there isn't much difference. Unfortunately, there are some serious gaps in the lineup of quality lenses for the 5D. There are no top quality lenses below 35mm. On the other hand, if you want a 24mm angle of view at f/1.4, Canon has one and Leica doesn't. If you want to throw the background out of focus at bit with a 24mm angle of view, only Canon can do it, but don't count on the edges or corners being sharp.
With respect to high temperatures I have not direct experience; only secondhand information that seems to indicate that most digital cameras become unreliable when the air temperature is 40°C, and especially when in addtion the sun shines on black cameras. Due as much to mass as anything else, pro format DSLR's will fare better for a while, and they'll definitely fare better than an M8 with respect to fine sand. That's one area where film cameras also have problems; every 36 exposures you have to open your camera and chance getting sand into the film chamber.
With respect to his filter comments, if he gets the filters scratched easily due to sand, etc, he should put a UV filter over the IR cut filter. Yes, it's another layer of glass, but the Leica lenses with IR cut filters have in my experience been fairly flare resistant, and often better than Canon lenses by themselves. The Canon lenses when used in Iraq would also need a UV filter to protect them. Putting an additional UV filter over the Leica lenses would not ever produce vignetting.
The sluggishness he speaks of is in part due to shooting jpegs. Shooting dng's the camera is a lot quicker. Using 2Gb Extreme III cards the camera can shoot 12 pictures before the buffer is full, and will flush completely in 15 seconds. That is hardly competitive with a 1DMkIII, but it generally allows shooting at about the best real rate that you can with a film M. With respect to startup he has a point, but I generally leave my camera on and carry exta batteries.
So in the end the cost and reliability remain as major downsides, and they are considerable. Other reasonable downsides are some of the design/layout issues such as menus, selftimer and bottom cover. Unfortunately pretty much every camera has some of these and only in the more evolved cameras do some of these go away. That has to be weighed against carrying and using a pro Canon body and lenses. The rest of his points are for the most either in the nature of the rangefinder or in the nature of digital photography as it stands today, or how he chooses to use his camera.
This is not so much a camera review as a report on his personal interaction with the camera and how it doesn't do what he wants in the way that he wants it to. That's completely valid, but for him alone.
I will not now give up the M8 (or an evolved version), but neither will I give up an SLR. They're just not interchangeable.
End of ramble.
Henning
